removing cam chain tensioner
kion
- My Bike: zxr400
In the manual it says only udo the bolts half way, did that but how do toy get it out?
ride with pride
kion
- My Bike: zxr400
Re: removing cam chain tensioner
anyone??the manual is crap. just undd the bolts, is out now, how do i fix it.
can compress the push rod, my key board is full of oil lol.
ride with pride
is yours the type with the hole for the holding wire??
Personally ive never done one so dont know
But manual here gives instructions
http://www.zxrworld.co.uk/Manuals/H%20M ... er%204.pdf
page 4-9
page 4-9
kion
- My Bike: zxr400
ye mine is the type with the hole or holding the wire, i took it out, is the hole undr the tapper part?
people on the other forum said the tensioner is not ruseable ill have to buy a new one?
so i push the rod dowm stck the wire in put it bak on, take wire out.
ride with pride
you got it mate then the tensioner arm will rise to the tensioner an as it wears the arm extends and keeps it tight, clever kwaks!!
kion
- My Bike: zxr400
ahhhhhhh this is the seventh most stressfull day ive had.
put it all bak and pulled the clutch in and was stiff then ndidnt work, cable is fine its the bit where it attaches to the tensioner the big bolt thatr connects the steel washer to the tensioner was out so i put in bak in and it worked and after 1 min it broke again???made a click noise when it broke, also i cant get the bolt the full way in? :smt013 :smt013
ride with pride
Not 100% with ya but dont think you coulda got the bolts the wrong way round? ones not longer than the other is it?
Just had a browse at some pictures and the bolts you are on abou double up for the tensioner and the clutch cable adjuster?
kion
- My Bike: zxr400
no theres only one bolt, its quite a large one aswell.
ride with pride
kion
- My Bike: zxr400
also wat baffles me is that when i put it bak on it works for 1 clutch pullin? so it can be the cable can it.
ride with pride
I though there was two smaller allen bolts either side of the large one?
kion
- My Bike: zxr400
no thats on the tensioner, i have a diffrent tensioner, i can put the tensioner bak on finre and the clutch screw it just doeswnt hold when i pull the clutch, i think it is internal.
ride with pride
got any pics of the bit you mean??
kion
- My Bike: zxr400
you know the clutch cable, it attaches to a large bolt on the left of the tensioner, that just clicks every time i pull the clutchin and then the clutch just becomes loose. i think the tensioner is nackered wont come all the way up, with out me pulling it.
ride with pride
Is everything you see here what you have on yours?
