carb heaters
rover220
My Bike: zx7r p6
carb heaters
Post by rover220 »
can anyone tell me if these carbs (in the pic) are the heated variety
Re: carb heaters
in short, yes ;)
:smt016
rover220
My Bike: zx7r p6
Re: carb heaters
Post by rover220 »
RobB wrote:in short, yes ;)
:smt016
lol, cheers.
i presume the brown looking cylinder thing is the water feed?
Re: carb heaters
yeah thats right, theres a pipe which routes from the left hand side of the radiator and down underneath the genny cover. Around there, there should be a take off for a pipe which routes upto that brown bottle type thing :)
rover220
My Bike: zx7r p6
Re: carb heaters
Post by rover220 »
RobB wrote:yeah thats right, theres a pipe which routes from the left hand side of the radiator and down underneath the genny cover. Around there, there should be a take off for a pipe which routes upto that brown bottle type thing :)
nice one mate
cheers :smt001
Re: carb heaters
ok, so what is the brown bottle type thing for?
Re: carb heaters
no idea Baz, i assume it could either be a filter or just a way of telling to see if the system is full as it goes the colour of the coolant you put in.
Re: carb heaters
i always thought its a filter, mine was green tho
Re: carb heaters
could it be a pump to prime the pipes??
Re: carb heaters
might be, not sure how that would work tho.
Re: carb heaters
its only soft plastic aint it? i think i've got one at home i'll have a look over the weekend.
Re: carb heaters
nope mine was hard plastic, nout you could do with it. My CRM heater dosent have one tho
Re: carb heaters
scrap what i said it goes round the other way! The big pipe round the genny cover has a smaller one that routes upto the other side of the carbs, then then a pipe comes off from the bottle type thingy which then plugs into the back of the engine underneath one of the inlets. This picture shows it nicely, underneath inlet number 1 with the pin for the thermostat or whatever it is just in front of it :smt001
mongo
Re: carb heaters
Post by mongo »
the plastic cylinder houses a filter. You should always open this up and take the filter out and give it a good clean when changing the coolant.
The colour of the cylinder will depend upon what colour your coolant is :smt003
