fuel pump flow rate
lubricantpixie
My Bike: Daytona 675/ ZXR 400
fuel pump flow rate
Post by lubricantpixie »
right the other day my fuel pump decided to give up. it didnt have enough grunt to pump the fuel over about 4000 revs. i replaced it with a second hand pump and now the bike runs. the problem however is that this second pump is also on its way out and doesnt pump above 8000 revs. i phoned up kawasaki and they quoted me £108 for a new pump which is a bit on the pricey side, so i was wondering if anyone knew the flow rate of the pump so i can get a non kawasaki one, or if i could use a different pump to the same effect.
Why are women like hoovers?
When they stop sucking just get them a new bag.
Re: fuel pump flow rate
I imagine the flow rate varies with engine speed, becuase of the different amounts of fuel used at differnt RPM. That is a tad pricey tho aint it!
lubricantpixie
yeah i kinda guessed that but what i was wondering was whether there were any specifications for the pump. ie maximum and minimum flow rate. yeah little bit pricey.
Northern ANdy
My Bike: Unique ZXR400
Post by Northern ANdy »
having just read the manual, the pump only operates intermittenly, pumping when there is low pressure on the outlet side, and shutting off when the pressure reaches a certain level. So from that I would assume that the pump is hardly running much at idle but batting around quite merriley at large throttle openings. The manual doesn't mention flow rate, but does give a pressure at which the pump must shut off.
Andy
lubricantpixie
oh nice one mate, i have bought another second hand one, lets just hope this one can pump well enough so i can get my top end revs back
