help- asap
kion
My Bike: zxr400
help- asap
Post by kion »
bike wint start makiing realy loud poping noises???
ride with pride
kion
My Bike: zxr400
Re: help- asap
Post by kion »
its flooded so i gonna wait till plugs dry up, then try.
ride with pride
kion
My Bike: zxr400
Re: help- asap
Post by kion »
Still cant get it started, would the plugs still be wet?
ride with pride
Re: help- asap
plugs shouldn't be wet, sounds like you have no spark, change the plugs, check HT leads and coils if you can, could be the cold weather has killed the battery?? does it turn over ok??
Re: help- asap
He might have no spark cos the plugs are still wet, ive had the same problem before. What i did was take the plugs out, clean them, re-set the gaps then stuck them on the gas hob for a few minutes to warm them up. Stick em back in and it should fire up right away with a bit of smoke which soon clears. Be careful when you take the plugs off the hob, obviously they will be hot! Also stick the battery on charge while you do it, give a bit of extra power for when you come to start it!
rover220
My Bike: zx7r p6
Re: help- asap
Post by rover220 »
it will be flooded still, zxr's are prone to flooding very easily
Re: help- asap
