slipping at 10k rpm
~JB~
slipping at 10k rpm
Post by ~JB~ »
my bike has a little issue at the moment, when going balls out the revs seem to increase faster than the bike is accelerating at 10,000 rpm.
Any ideas? i was thinking maybe clutch or slipper clutch....
Ta,
James
zxr_oli
My Bike: Daytona 675
Re: slipping at 10k rpm
Post by zxr_oli »
Would have thought it would be the normal clutch that is slipping.
I would take a look at the plates :)
stu71
My Bike: ZXR400sp
Post by stu71 »
sound like the clucth my race bike did it end of the season at about 10,000 from 3rd gear up, stripped it down and found only 1 had worn down bad, i know a lot of racers have trouble with clutchs slipping at ours, mine was the ebc kevlar ones and didn't last a full season, maybe if any other racers see this what have you found to be the best ?
definitely sounds like the clutch is slipping, have you tried adjusting the cable?
~JB~
Post by ~JB~ »
cheers guys, i'll try adjusting the cabel in the short term, but will have a look at the plates soon as i can.
thanks :smt001
zxr_lover
My Bike: ZXR400 H model
Post by zxr_lover »
~JB~ wrote:my bike has a little issue at the moment, when going balls out the revs seem to increase faster than the bike is accelerating at 10,000 rpm.
Ta,
James
I get the exact same problem mate, hasn't given me problem over the months so haven't really looked into the cause. but now i know what it could be, will get the clutch looked at.
Graham
A slipping clutch can often be caused by have the wrong oil in your bike.
Any car oils should be avoided and avoid mixing fully syn with semi or mineral. Even if your doing an oil change
When fitting new clutch plates they should be soaked overnight in the same oil as is in your bike
In fact change the oil at the same time
~JB~
Post by ~JB~ »
I found that is was probably mostly down to the knackered front sprocket, almost round :oops:
have replaced it now, i know i'll need to replace the chain and rear sprocket at some point soon too, but i couln't afford it at the time.
If you were riding on a bike with a front sprocket so worn that it seem liked the clutch was slipping at 10K plus RPM then my friend you are lucky to be alive.
Chain off......... broken engine cases...........chain jammed in rear wheel............ wheel locked................big crash......................................
Got a piccie of the sprocket JB?
~JB~
Post by ~JB~ »
no, i don't, i'll get one tho and put it up. :smt001
good stuff, i wanna compare it with the sprocket off of my XJR400, didnt think id ever see a sprocket so rounded off! Mine used to spin and judder like a cnut. Have you managed to test it yet and see if its cured it?
~JB~
Post by ~JB~ »
yeah, it seems to have cured it, tho i really do need to change chain and rear sprocket asap, you can see the chain doesnt sit snuggly in the rear sprocket. doubt i'll be riding it this month tho because it's at my parents, hopefully get it fully sorted by feb.
EDIT: Image added :smt001 JB
shocking shocking shocking shocking shocking shocking shocking shocking shocking shocking shocking shocking
dont seem to be able to find my one :? god knows where thats got to then. Werent as bad as that tho, didnt you feel it judering as it slipped over the teeth?
