masterofinsanity wrote:yep soldering iron and a plastic coat hanger gets my vote too, halfords used to do a proper fairing repair kit.
I'll take your coathanger and raise you some plastic lock-ties!
they're about the same elasticity as most fairing panels, so actually work quite well, because brittle plastic will snap.
In my experience, even this won't do you any good on and around the actual fairing lugs, though...
There's a tin of gooey fibrglass stuff that works ok, but same story again with the lugs.
I'd advise shelling out for a proper plastic welder to do it for you.
EDIT: Oh, and I thought the Halfords kit was crapola. I had to take it back twice because various things in the kit had dried up (which was REALLY fun when I was halfway through the repair), and even then it was very fiddly and messy.
