Clutch problems
nickp
Clutch problems
Post by nickp »
I've had a feeling that the clutch is on its way out, and yesterday kinda confirmed it.
Normally when I pull away in the morning out my driveway slowly, it shudders slightly as I release the clutch. Can only be felt when moving off slowly from a standing start.
Yesterday I was pulled away quickly, nailed it, up into second, as as it hit 10,000rpm in second the revs started to rise way to fast, but there was no increase in acceleration, just loads more revs and loads more noise. Sounds to me like the clutch is on its last legs. The bikes done 18,000kms (+/- 3000miles)
Re: Clutch problems
have you changed the oil recently?
rover220
My Bike: zx7r p6
Re: Clutch problems
Post by rover220 »
definetely sounds like clutch slip.
try a different oil as a first point of call. 10w/40 semi should be used.
