clutches
tobomoto
My Bike: zxr400l4 zx7r
clutches
Post by tobomoto »
a mate is having problems with his clutch. basicaly its as though its still biting when the lever is pulled in. tried adjusting it at the lever but the thread is knackered and the cable isnt even sitting in it properly. weve adjusted it at the engine end to no avail. the cable is only about 2 months old so hasnt had much use due to shitty weather. does it need a new lever assembly or clutch? if it is a clutch, how difficult are they to change and what is needed (plates, springs etc)?
Re: clutches
Sounds like it's not lifting properly
Get the external bits working properly before you go delving into the clutch itself
Knackered threads doesn't sound good
Cable not "sitting in" properly doesn't exactly insipre condifence
If it is plate or springs it's a relatively easy job to replace them
