Does anyone know the piston pin diameter?
I checked workshop manuals but there is no
information regarding this. All pistons
1989-1999 use same diameter piston pin,
since them share same piston pin clip
92033-1151.
Can someone measure the piston pin
diameter either from piston or piston
pin? ZXR250 uses 13mm pin so ZXR400
most likely has bigger pin.
Thank you
ZXR400 piston pin size
Re: ZXR400 piston pin size
just measured one in my shed it is 40mm long and 15mm wide if thats any help to you
mike
mike
