Right. All is sorted gents, and I've got a myriad of photos which I'll sift through later on, and post up as detailed a write up as I can. I lost a couple of parts though.
The spacer for the bolt holding the clip on the choke cable housing went down and inside somewhere, and one of the fairing bolts did too, but we've sorted it all out.
The jubilees I was on about are on the top of the rubber trumpets the washers are placed under, and they were phillips head. I got those undone and then was able to remove the whole carb assy in order to get at the allen bolts holding the trumpets to the inlet itself.
I think I've managed to get photos of more or less everything except the washers sitting on the inlet, which I intended to, as we came back up from downtown to find my friend's dad had already whacked them in and slapped some sealant on. I got some of looking down into the inlet with the washers inside.
Going for a ride now, and then a barbecue, I'll do the write up when I next sit down at my computer. Thanks for the help guys!
Oh, and Zimm, I owe you a lollipop!
