Hi all. got a prob. the bleed nipple has stripped the thread on the caliper and wont nip up. i had the same on the rear a few yrs ago but just chemical metalled it up as it had another bleed nipple on the other side of the caliper.
I dont have that luxury with the front caliper. any ideas?
Nadges! Stripped Thread.
- diesel
- My Bike: Zx7r
- jake
Re: Nadges! Stripped Thread.
how bad is it? could you strip it and retap the thread?
- diesel
- My Bike: Zx7r
do they do larger bleed nipples? thats an option i spose. its too bad to be tapped out to the same size.
- zxr_oli
- My Bike: Daytona 675
Tap a new thread then use a helicoil to bring it back to size?
yes you can get a bigger bleed nipple so you could always drill and tap it out a size.
masterofinsanity wrote:yes you can get a bigger bleed nipple so you could always drill and tap it out a size.
+ 1
helicoils wont work, the fluid will seep out.
