well my bike has started making a wierd noise and somebody has told me it could be the thrust nut on the clutch come loose? any guides or information on this?
thanks
Clutch noises?
Re: Clutch noises?
It's not a thrust nut it's just a nut and I've never heard of one coming lose.
ZXR400 clutches can be very nosy.
Maybe perhaps you could describe the noise more clearly..............for example does the noise change when you lift the clutch..............(pull the lever in)
Does the noise change as you rev the bike ?
Is it just there at a very specfic revs?
Have you changed adjusted or worked at anything on your bike that might now be causing it to be nosy ?
nitro_rhys
Re: Clutch noises?
well i had to adjust the clutch the other week cos the bike would creep forward when in gear and the clutch was fully pulled in. I took the bike out tuesday didnt notice anything, took it out thursday and i can hear this noise. Its mainly at around 3,000 revs and its like a gargling type of noise, like a bolt may be loose or something spinning that type of noise. I have had to adjust my clutch again too.
Re: Clutch noises?
sounds like a zxr400 clutch.
zxrjohn14
Re: Clutch noises?
aah the old 'sounding like a bag of spanners' clutch.
its a normal thing for the zxr.
nitro_rhys
Re: Clutch noises?
its also doing it at 5,000 revs now lol. You think its ok then? it just it wasnt doing it before
Re: Clutch noises?
whoever told you thrust nut probably meant thrust bearing. But its defo not that, theres a plate in the clutch that does it.
Was a new clutch installed recently? I friend of mine took his back to get it sorted under warranty, cured it for about 3 days then it just came back.
nitro_rhys
Re: Clutch noises?
not that know of, iv been riding the bike since may and aint heard it, Il get a recording but you have put my mind at rest
