When i bought the bike it needed a new wiring loom, i was told that any would work so i bought one from an L8 model which turned out was slightly different so I swapped over a few of the connections to get everything working like the indies and lights etc and I have no problems with them now and the engine starts fine.
I have taken some photos of the back of my clock for you to look at because i honestly cant see why it wont work.. :smt013
First of all here is a picture of the CDI that it has:
21119-1331
1318005600
12v TNCF16
DENSO JAPAN
I have read that the blue one is the right one to have as its the UK one.
Now, there is a small box which says M-Max on it which ive discovered is meant to be the derestriction but its not working for me :p
The cable in my hand in the picture is what the box is connected to.
Now here is a picture of the connector block which the M-Max box is connected to and there is a pink wire which has been cut.
However, here is what that block connects to and were the pink wire goes in there is nothing for it to connect to...
So i am completely lost as from what i can see my bike should be revving out!
Here is a pic from the back of the clocks too just incase.
Hope someone has an idea because I certainly dont
Cheers,
Scott.
