Smell of fuel
Smell of fuel
was speaking to baz over wkend and he said when riding behind me u can smell petrol from exhaust
is has a race can on it, but apart from that its standard
maybe its running a bit rich, but the performance and response off the throttle is bang on
is this smell of fuel simply cuz there are no baffles in the can? so its easier for any unburnt fuel to b blown out the back?
Re: Smell of fuel
He must have some nose if he can tell that the petrol smell is from your exhaust..............
Could it be that he's smelling petrol from the big tank between his legs ????
Re: Smell of fuel
it pops rather a lot on deceleration but zx7rs do this apparently.
i aint really bothered as it runs mint, and so to me this means the fuelling is spot on...
im just curious if it could be the definate lack of baffles in the can which allows free passage for any unburnt fuel to escape
Re: Smell of fuel
must have a proper jew nose to pick that up..
The only way you'll no for sure if the fueling is spot on is on a dyno, and if its standard jetting i can tell you for fact that the bikes fueling is crap like they always are out of the factory
Re: Smell of fuel
well i have always said,
if it aint broke dont fix it
so will leave it, maybe stick it on the dyno but thinking of upgrading next year anyways
Re: Smell of fuel
if you can make it better then why dont you? Sake of a few hundred you get a much more rideable and quick bike sounds worth it to me..But then whats worth while to me isnt always the same for you.
Re: Smell of fuel
as i said, the ride and performance is faultless...
Re: Smell of fuel
feck all wrong with my nose and jamz zx9 is even worse, the fumes from that knock you out!
Re: Smell of fuel
must b race cans then
Re: Smell of fuel
I noticed that it pops alot when you rev it, so it might be running a touch rich. If your worries get your plugs out and have a look. Other than that, keep it how it is, it sounds mint!
Re: Smell of fuel
masterofinsanity wrote:feck all wrong with my nose and jamz zx9 is even worse, the fumes from that knock you out!
You said that about my VFR! I reckon you're just picking on me! :smt009
:smt005
Re: Smell of fuel
Scott221 wrote:I noticed that it pops alot when you rev it
zx7rs are renound for it when u throttle off mate
Re: Smell of fuel
The ZX7R's run stuiped rich from the factory iirc. They also have loads of emmsions crap that you can pull out, with it on its not possible to get the bike running sweat fueling
Re: Smell of fuel
same with zx6's, they pull air in through 2 reed valves on the cam cover and dump it into the exhaust headers on the over run to "lean out" the emissions, but it also makes its pop and bang .. folk just pull it all off and fit blanking plates.
