Rear Caliper
THE FLUTE
Rear Caliper
Post by THE FLUTE »
JUst purchased this rear caliper to fit to my ZXR make it easier to change the wheels Will have to make a hanger for it but will make it captive for when the wheel is removed :gamer
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0089288083
Re: Rear Caliper
very nice are you mounting it from the top?
THE FLUTE
Re: Rear Caliper
Post by THE FLUTE »
Yes Mate going to fit it from the top and drill and tap the the slider plate on the swingarm so it will slide with the spindle but not fall out when i take the wheel out. Should make it easiesr when changing wheels 8 times a day :pmsl
THE FLUTE
Re: Rear Caliper
Post by THE FLUTE »
Well Made some progress with the caliper and hanger Just need to weld it together and make a piece for the swingarm and get that welded on as well Think it should make wheel changes easier and it,s lighter than the standard set up biggrin
Re: Rear Caliper
looks cool, ..
liking the dymags, they the ones that were on ebay recently ? do they make a noticeable difference to how the bike feels ?
will#224
My Bike: L1 racer
Re: Rear Caliper
Post by will#224 »
Whats the benefit of mounting it up top, i'd have thought it being underneath would lower the C of G and would allow the wheel to be captive to some extent when removing spindle etc?
THE FLUTE
Re: Rear Caliper
Post by THE FLUTE »
zimm wrote:looks cool, ..
Yes got them off ebay Front is 1.4kg lighter and the rear 1.6 so should make some difference biggrin
THE FLUTE
Re: Rear Caliper
Post by THE FLUTE »
will#224 wrote:Whats the benefit of mounting it up top, i'd have thought it being underneath would lower the C of G and would allow the wheel to be captive to some extent when removing spindle etc?
Yes but when your trying to change the wheels in a rush to fit wets you need three hands to hold evrything in place This way the caliper actually stays in situ as you drop the wheel out then just put the other wheel straight in :excited
Re: Rear Caliper
its a lot of hassle just to make wheel changes easier, its not really that hard if you put the spindle in from the sprocket side..
does look trick though.
Re: Rear Caliper
there is a reason kawasaki puts the spindle in from the brake side!! :smt002
THE FLUTE
Re: Rear Caliper
Post by THE FLUTE »
Well its all done and it makes it really easy to change the rear wheel now :excited
Re: Rear Caliper
is that 1 bolt gonna be sufficient to hold the caliper on braking? the way the wheel rotates i would have thought it will snap that bracket off in no time?
THE FLUTE
Re: Rear Caliper
Post by THE FLUTE »
masterofinsanity wrote:is that 1 bolt gonna be sufficient to hold the caliper on braking? the way the wheel rotates i would have thought it will snap that bracket off in no time?
Will find out next week :pmsl No should be fine it has the same set up on my old R6. The bracket is also held tight when you clamp the spindle up.
Re: Rear Caliper
oh right, does the spindle still go through it then?
THE FLUTE
Re: Rear Caliper
Post by THE FLUTE »
Yes spindle go's through the bracket too If you look by the washer on the spindle you will see 2 screws in the adjuster plate they screw through into the bracket and hold it in place when you remove the rear wheel.
