slipping choke
saka_ZXR
slipping choke
Everytime i put the choke on ready to start her up the choke slips off, the choke lever just wont stay up and keeps falling back, i have to hold the choke then start it and move the choke to the right place so its idling okay then i have to stand there holding the choke for a few minutes while she warms up. does anyone know what the problem is and how i can fix it?
lewisdale
- CBT slow
- My Bike: zxr400 H2
Re: slipping choke
maybe the bracket on the carbs that holds the cable have come loose?
Re: slipping choke
aint they all the same?
Re: slipping choke
It could be that the screws that hold on the choke pull have come loose. If you take the tank off and trace the choke cable that will bring you to the choke pull, thats a long bit of ally with bits that stick out to pull the choke plungers on each carb. Theres 3 screws holding this in place with a plastic washer on the front and back. Tighten the screws up and see if its any better.
- dower
- My Bike: ZXR400 L9
Re: slipping choke
Mine is exactly the same so I'll whip the tank off and check it out.
- U_h0rnet5
- My Bike: ZXR400
Re: slipping choke
Hey I had this problem not so long back. I took apart the indicator thing and cleaned it out and when i put it back on the clutch lever was not staying. My mate had a look at it and then just tighten up the two screws on the back of the black box. Dont know if this will help but have a look at it.
saka_ZXR
Re: slipping choke
Cheers guys i'll have a look at it tomorrow and let u know how i get on.
