pics of the bit i have to block off?
ratbag56
- My Bike: zxr400 / 636
any one got a pic of the bit u blank off in the carbs when u use 110 mains and ram air?
Fatspanner #44
- My Bike: Triumph Daytona 675
Re: pics of the bit i have to block off?
Just look at the intake side of the carbs and it is the brass hole just below the main air intake. There are 2 of them, but the highspeed corrector is the top one.
ratbag56
i see so i need to block the other one off? nearest the intake hole? (just checking and probably sounding realy dumb but me are looking at the holes under the inlet plate?)
- jake
yes thats the ones.
if the carbs are fitted, and your on the bike looking down at them, they are the upper ones to the right a bit. closest to the carb mouth.
use a bit of araldite, or plastic metal etc..
hatatfatcat
- My Bike: ZXR400H
Why do thes need blocking off exactly? (yes I'm doing the same mod!) Also on the intlets there are some rubber tubes connecting cylinder 1 to 4 and 2 to 3. I'm assuming thes are low speed balance tubes??? can I bin them and block them off?
Fatspanner #44
They screw things up if you are running without a filter or Ramair etc and makes the carbs much easier to set up. Blocking them prevents you from having to use massive main jets which would cause problems elsewhere. Not sure about the technical theory of how they normally work!!!
