bike wont fire up!!!!!!!!!!!!
- KAWASAKI_KID
 - My Bike: ZXR 400 L3
ive been tryin to get bike runnin for a while now!!!
no joy!!
its been to the workshop and come back whilst i've been abroad.
the bike has sat there for about 4 months unused
so its not starting now
the mechanic said " change the feul over as it may hav "gone off"
so ive drained the tank
what's thea easiest way to drain the fuel from all the carbs??
im used to kx's and scramblers,
so its a bit of a step up for me!!
any help is gladly welcomed.
got my full DAS on 13th 14th 15th so i want to get runnin asap
i hav the tank off already (right now!)
so any pics or advice is great
thanks!
									no joy!!
thanks!
Veni Vidi Vici  -  I came,  I saw, I conquered!
Show Spec - 1988 Escort Mk4 XR3i Cabriolet
Kawasaki ZX6R J1
Kawasaki ZXR 400L3
Kawasaki KX 100
Saving for a jet Ski...kawasaki of course! lol
Kawasaki ZX6R J1
Kawasaki ZXR 400L3
Kawasaki KX 100
Re: bike wont fire up!!!!!!!!!!!!
i would take the carbs off and remove the float bowls see what state they are in inside the carbs.
				parby81
 - My Bike: ZXR400 L9
as above, but as for your question on the easiest way, undo the fuel drain screws.
There is one on each carb with a 2/3mm allen key head. Have something under each carb to catch the fuel as it comes out.
And it takes a while to fire up with new fuel as the float bowls have to be refilled.
				Davw
Few questions:-
1) Did the bike run before being stood for 4 months?
2) Have you charged the battery?
3) Have you checked you are getting sparks at the plugs
Easiest way to check all of this would be to remove the tank and hook up the fuel line temporarily (with the tank on a workbench or turned through 180deg and restingb on the seat), remove the air box and with the carbs facing you, squirt some Easy Start directly into each carb air intake (gently lift the airslide to ensure it gets to the intake). With fully charged battery you will get the engine to fire (assuming there is a spark). If engine doesnt fire then there is a problem with the sparks (or lack of)
good luck
good luck
						- KAWASAKI_KID
well ive just got it back from the mechanics and it sat there 4 ages.
he said it was runnin beautifully before he brought it back!...he would do! (Mechanics!!!!)
so probably a fuel thing, plugs are sweet theyr'e brand new so that shouldnt be a prob
i've gotten too frustrated with this thing!
so i've took it to a local garage to get it sorted!
i will end up setting it on fire or sellin it for a fiver,....too much assin about!
so maybe sumone will get a deal real soon if it fucks up agin.
thanks anyway for your help
Kawasaki ZX6R J1
Kawasaki ZXR 400L3
Kawasaki KX 100
Kawasaki ZX6R J1
Kawasaki ZXR 400L3
Kawasaki KX 100
				parby81
If you only want a fiver, I'll have it!!!!!!
						- KAWASAKI_KID
ha ha lol...no chance!
naa just winds me up wen it all aint just plug n play!! lol
theres too much love in there for a 5'er
Got it real cheap..newly rebuilt engine just needed sum TLC and a few parts, and it also now looks the bee's knee's
just wanna get on the 'wretched' thing lol
Kawasaki ZX6R J1
Kawasaki ZXR 400L3
Kawasaki KX 100
Kawasaki ZX6R J1
Kawasaki ZXR 400L3
Kawasaki KX 100
				bikerboi1946
 - My Bike: berg fs650
dibs on the engine!
						- KAWASAKI_KID
bikes runnin sweet now. thanks
Kawasaki ZX6R J1
Kawasaki ZXR 400L3
Kawasaki KX 100
Kawasaki ZX6R J1
Kawasaki ZXR 400L3
Kawasaki KX 100
				Davw
- KAWASAKI_KID
well it needed some tlc in the carbs was a bit mankky in there after this long.
got a new problem now though!
i was at a friends this weekend, went to take one of there boys for a spin round the crescent on the back....
but gettin to a point where i needed to turn around. i put the steering full lock to the right and all the ignition has cutt out! no lights, no starting, no oil-level lights,.. nothing!
i checked battery terminal connection, all the fuses incl. the big 30 on the solenoid! they are all sweet.
my alarm is runnin direct from battery ok!
may be something to do with cable snagging but the cabling to the ignition barrel seems ok, didnty really have tools at the time!
so my bikes in sum ruff estate, parked outside, chained to lamp post, shining like a massive beacon to bare lil' theivin hood rats!!!
i need to get it workin and moved from there asap!
any one got any ideas or had this problem before??!
Kawasaki ZX6R J1
Kawasaki ZXR 400L3
Kawasaki KX 100
Kawasaki ZX6R J1
Kawasaki ZXR 400L3
Kawasaki KX 100
posted in your other thread
						- KAWASAKI_KID
nice-one baz...always there, to help out!!
much appreciated!
									much appreciated!
Kawasaki ZX6R J1
Kawasaki ZXR 400L3
Kawasaki KX 100
Kawasaki ZX6R J1
Kawasaki ZXR 400L3
Kawasaki KX 100
