Now I've got a straight through system (not my choice) so I guess that's the reason for the bigger jets. Before the head gasket went the plugs were a nice colour, so I know the fuel/air mixture was good for most of the rev range. Problem is it overfuelled on idle to the point of making my eyes sting! Question is - should I leave the fuel air/mixture as standard (2 1/4 turns or whatever it is) or should I dial it in a bit to reduce overfuelling on idle?
I'm a bit worried if I do this that the fuelling further up the revs will be messed up (guessing lean) - what do you guys think? Should I go back to 98s and put a removable baffle system on or just leave it as it is? Is it doing any damage to the bike with the bigger jets and overfuelling on idle?
One other thing - what's the gap on the plugs supposed to be set at? They're c9rek (double electrode finger thingys) if that makes any difference...
Thanks in advance!
Rach.
