Idling at 5000rpm
Dougal667
Idling at 5000rpm
Post by Dougal667 »
Morning all. I've a 1990 H2 ZXR 750 (UK Model) Yesterday it started playing up and won't idle at less than 5000rpm. The throttle and choke both open/ close fully and nothing looks out of place. Has anyone any ideas as to what could cause this and a solution to the problem. Thanks Dougal667
Re: Idling at 5000rpm
have you had the carbs off the bike as i did this with my gixer and forgot to screw the throttle return back in, butterflies may look closed but possibly not.
Dougal667
Post by Dougal667 »
Nope carbs haven't been off. Bike has been running as sweet as a nut since I got it 2 months ago, died a couple of times but that looks like the battery wasn't holdign a charge, new battery fitted and now this idling problem!!
has someone messed about with your idle adjuster??
Dougal667
Post by Dougal667 »
Bike as it was when I took delivery of it. Done 3-4 hundres miles on it and all been ok, just started yesterday... Wonder if some sh*t has been picked up from bottom of tank and blocked or jammed something!!! Oh my mechanical knowledge of bike workings is limited... Learning curve has started!
more chance of there being an airleak somewhere than blockages i would have thought, if you had picked some toad up in the carbs then it would splutter more than anything?
crushedlizard
My Bike: ZXR400 L2
Post by crushedlizard »
Could be something as simple as stuck choke? Mind you I think the choke idles at 7k doesn't it? Can't remember, but it's bloody loud on a cold early morning!
Dougal667
Post by Dougal667 »
All sortted. Thanks for all your help :smt001
what was it?
