Problem already.
Brett
- My Bike: zxr 400 h1
Problem already.
As I'm sure you all know I got a gsxr400. Just come in from riding it and noticed oil has been coming out of the right hand side of the head. Not huge amounts, but enough to go onto the fairing. The bike is running very well. Can I tighten the head to stop it leaking?
Action is the antidote to despair.
Brett
Re: Problem already.
i would be more inclined to do the head gasket before it goes and does more damage.
most likely the cam cover gasket mate.
Brett
well if its the cam cover then the engine will be getting low on oil if its losing it, if its the head gasket it could warp the head.
rover220
- My Bike: zx7r p6
an oil leak warp the head? are you sure?masterofinsanity wrote:well if its the cam cover then the engine will be getting low on oil if its losing it, if its the head gasket it could warp the head.
no i meant if the head gasket blows.
rover220
- My Bike: zx7r p6
if its leaking from the head/block join which is unlikely then the gasket needs replacing anyway. wont warp the head if its not overheating.masterofinsanity wrote:no i meant if the head gasket blows.
ok maybe i'm looking at extreme cases?
rover220
- My Bike: zx7r p6
maybe, maybe not.masterofinsanity wrote:ok maybe i'm looking at extreme cases?
im not sure how the head looks on one of these so dont know where the oil feed runs on them. could have overheated in the past and warped the head though but id go with zimm (cam cover)
Brett
It does seem to get very hot, although the gauge doesn't reflect this. The exhaust stays too hot to touch for about half an hour after riding.
yes because exhaust temp is a good reflection of coolent temp...
- deviant
- My Bike: ZXR400 L3
are gixxer 4's water cooled? or are they oil cooled like the 750s/1100s of that era?
anyway. my money's on the rocker cover, purely because my ZXR's been leaking from there. I took it off last night and supplemented the rubber seal with a bead of instant gasket before torquing it back down. hopefully that will have sorted it.
post a pic up of where its leaking from.
