I Seem To Live In Here! Tool Needed
diesel
My Bike: Zx7r
Post by diesel »
Hi all. due to major ongoing technical problems i have the opportunity to re-grind the valves but have no Valve spring compressor. Do any of you have one i can buy/borrow/hire.
or a suitable tool bodge for said jobby.
This bike WILL run again i tell thee.
Quicker Than Yngwie
zxrjohn14
Re: I Seem To Live In Here! Tool Needed
Post by zxrjohn14 »
hi diesel,
i use a long reach socket (about 16mm) with a magnet inside (place the magnet on top of the spring retainer over where the collets are), a long bar and ratchet on the end of said socket, and push down, then the magnet picks up the collets. make sure the magnet doesn't foul inside the socket tho'. and the ratchet is only on to make it easier and not so painful when you push down!
then to put them back, get a friend, a strong one, to push the spring down with a pair of pliers while you put collets back in place.
its a bit of a rough way of doing it, but it works.
hope this helps and makes sense!!
:gamer
diesel
My Bike: Zx7r
Post by diesel »
zxrjohn14 wrote:hi diesel,
:gamer
nice one. ill see if i can make that work :)
Quicker Than Yngwie
If said friend with pliers uses long nose pliers they'll come in handy for fetching collets out of your eye..................
http://shop.ebay.co.uk/?_from=R40&_trks ... Categories
