can you convert total loss?
Paul
- My Bike: zxr 400
hey eveyone this is my first post. i am wanting to get a zxr 400 race bike but i want one without total loss but all race bikes i see for sale are running total loss. How could i wire up the button start back on
Paul
Paul
Robbie
- My Bike: zxr400
Re: can you convert total loss?
Total loss is no charging system.most should still have starter and start off button you just need to charge the batt more often.
Paul
- My Bike: zxr 400
Thanks, i thought it meant that there is no ignition and you always had to bump start it
zxr500man
hi,what is the advantage of a total loss system?
Davw
weight reduction and the engine will spin up faster (removal of the crankshaft mounted rotor). Wiring loom then simplified and no need for a regulator as there is no charging currnet to regulate (more weight saved)
zxr500man
will the battery not go dead?
yeszxr500man wrote:will the battery not go dead?
Thats why u have to charge the battery morr often.
-GQ-
Whenever mine is not on the track, it is on the Optimate.RedexRobB wrote:Thats why u have to charge the battery morr often.
The battery will not just discharge, but become unusable if you don't charge it regularly. I used to just put the charger on every few days or so, but now just leave the Optimate on.
zxr500man
i think thats just a bit to extreme of a mod for me
Davw
Not extreme at all but only worth doing if you are racing otherwise a total pain in the butt if you are just road use
