Tight Clearances
Azazel
My Bike: ZXR400 L1
Tight Clearances
Post by Azazel »
Hey everyone - could do with a bit of advise please....
I have just check the clearances on me L1 due to a 'tapping' sound - I found that most of the clearances are tight.
The worst is #2 inlet (0.08) which should be between .12 - .17. Could this be causing the tapping? All of the Shims are between 2.75 and 2.90.
It only taps after about 4.5K revs.
I notices my cam chain tensioner rod is fully out so tensioner will need replacing - could this be something to do with it?
Many thanks in advance
extonyg
My Bike: zxr 400 L1 uk
Re: Tight Clearances
Post by extonyg »
sounds more like cam chain or guides to me, fully extended tensioner says to me that the chain is worn, but yes u do need to adjust the clearances into spec but tight clearances wont be noisey.
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
Needing a complete overhaul there , sounds like you caught it in time though !
Tight is bad shocking But good for HP shocking shocking So most never notice as your bike goes like fook to self destruction !
Camchain , guides , tensioner and shims - get them replaced and set up again.
Do a check again in 3,000 miles time and see if your clearances are tightening up again - take acurate measurements not just within clearance.
If your motor has a tendency to tighten the gap you need to monitor more - loose is good as power goes down and you notice.
If your setting up a race engine you want as tight as possible - these are stripped regular so cause no issue.
MM!
Azazel
My Bike: ZXR400 L1
Post by Azazel »
Thanks very much.
Will get on it and update you ASAP.
THANKS AGAIN!!!
