I have just check the clearances on me L1 due to a 'tapping' sound - I found that most of the clearances are tight.
The worst is #2 inlet (0.08) which should be between .12 - .17. Could this be causing the tapping? All of the Shims are between 2.75 and 2.90.
It only taps after about 4.5K revs.
I notices my cam chain tensioner rod is fully out so tensioner will need replacing - could this be something to do with it?
Many thanks in advance
