L2 resto - first time for everything
stonemonkey
My Bike: Zxr400 L2
Post by stonemonkey »
Hi All, Thought Id put up a build thread of my L2 as I have done for the majority of project cars I have had. I haven't long passed my test and have bought a nice L2 from an owner on the forum. Before insuring the bike I am going to strip, clean and refurbish the bike over winter as I feel it will be a great way for me to learn more about the bike, and it to will allow me to have the bike spic and span for spring/summer. It will be a massive learning curve for me working on this however I am a mountain bike mechanic and have a reasonable knowledge about car mechanics so think It'll be fine.
Plans are to strip to the frame, repaint and rebuild seeing to every bit of 'rust', paint flake and 'odd' bolt. And of course a few personal touches. biggrin
Hers a few piccies of previous cars - (sorry in advance for putting four wheelers up :smt021)
Here's how the bike started...
I had an afternoon off so though I'd spend a couple of hours getting the project rolling.
Re: L2 resto - first time for everything
nice pics, can we see some of your mountain bike?
stonemonkey
My Bike: Zxr400 L2
there you go..
stonemonkey
My Bike: Zxr400 L2
Bit more work done today. it amazing how much muck and grime there can be once you start removing bits when something appears so clean on the outside. Just had a quote for my powder coating at a bargain price so hopefully progress will be quicker than planned.
DIRT
MORE OIL AND DIRT
Am going to need opinions on colours as i'm undecided. Thinking of satin black frame and brackets with kwak green fairings and black decals. With the subtle gold highlight to F and R calipers, forks, rear master cyclinder and sprocket bolts.....
stonemonkey
My Bike: Zxr400 L2
Nearly there, only the swing arm and forks to remove now.
FILTH :smt078
dirty donkey...
stonemonkey
My Bike: Zxr400 L2
managed to get the swingarm off today however I now need to tackle the knackered bearings inside the swingarm.
Painted the shock though as it was a bit more relaxing.
Before
stripped
I then soaked the parts in white vinegar to chemically strip the rust and ease the grease. Heres the after results which Im very pleased with biggrin
Painted, built and copper greased.... Spring is going off to be powdercoated with the other bits
Then had a little time left. Rear master cyclinder
Cleaned and painted
More to come soon Ihope
stonemonkey
My Bike: Zxr400 L2
full rear brake setup done now, got new pins for £3.25 for the pair including individual clips and a single piece clip which i decided to use as it holds them in the correct position and is less fiddly.
Really pleased with the finish of the paint.
stonemonkey
My Bike: Zxr400 L2
few more bits done, Front brake setup finished as well as hand polishing the rearsets :smt015 . Swingarm bearings have now been removed so frame will hopefully be going for powdercoating next week sometime.
before:
after
GoldenBalls213
My Bike: ZXR 400
Post by GoldenBalls213 »
Hi..
Lovin the calipers! :smt002
What paint did you use? I'm about to overhaul my calipers and i'm unsure of what paint to use!
Are those the original caliper half bolts just polished up a tad?
Keep up the good work! :smt002
GoldenBalls213
stonemonkey
My Bike: Zxr400 L2
Hi, yeah the bolts are the originals just polished up with wire wool, I used some high temp engine paint off ebay for the calipers however the finish is almost like a satin gold. I got asked if they were anodised by a friend at first glance. I can patch the link through if you want?
GoldenBalls213
My Bike: ZXR 400
Hey!
Yeah pls post the link it would be much appreciated! Cheers..
Im after the same look however my caliper bolts are in pretty bad shape, will try cleaning them up first, But i had to by a new one today as it was stripped taking it out someone has used the wrong size screw to hold the plate on and it looks like it has crushed the bolt hole! rather strange!
Thanks!
stonemonkey
My Bike: Zxr400 L2
here's the link
http://www.ebay.co.uk/itm/300506345512? ... _658wt_932
it is really funny to apply as you need thicker coats.
skeeno72
My Bike: zxr 400r
Post by skeeno72 »
looking good mate be great to see it when finished so can compare with mine
stonemonkey
My Bike: Zxr400 L2
Yeah Im trying not to rush as i have all winter. What's your timescale?
skeeno72
My Bike: zxr 400r
Post by skeeno72 »
well im doing an diploma in plastering at the min that finishes in feb i do 2 and a half days a week then the rest of the time is on the bike so looking about 2 months hopefully i bought frame and arm already painted so just a matter of swapping and cleaning as i go
