neutral wire
Re: neutral wire
got to admit i rarely leave the side stand switch on my bikes, ungly and cause problems, just easy to not have one!
carsounds_dan
Re: neutral wire
Post by carsounds_dan »
it wont pull away with the side stand down. but if i put a positive up the start wire in the fuse box (yellow/red i think) then it will crank (the alarm splices in there). so atm if i press the remote start with the bike in gear it will jump off the side stand and roll down the road.
cheers
dan
...i know, it's great :D
Re: neutral wire
so by doing what you have you must be inserting a live feed after the sidestand switch, you need to connect it before . :smt003
Re: neutral wire
yup, i would make sure all switches are working but it sounds like the stand an wires from the clutch are ok (doin there job at least) you need to look further in the bike for the rest i recon its a take the bike half apart joby, ouch. much easyer to leave the auto start out :smt003
