I'm just replacing the head gasket on my race bike. Ive done done it before on a standard bike no probs, the only difference with this engine is its had a bit of tuning work done including 0.5 oversize pistons. My question is, is the stock gasket ok to use 'as is'? I know the thickness is ok and I know I need to re-profile slightly wear the valves sit to line up with where its had been re-profiled on the barrels, but I would have thought the stock gasket would be 0.5mm to small on the bore, yet I keep looking carefully and its seems ok. Are the stock gaskets produced to allow for a slight overbore?
Any experience anyone can shed on this would be much appreciated?
Also I need a few shims, a bit deeper the usual, around the 3.35 mark as I'm running kent cams. Anyone know a good seller?
Max
