OK, I'm stripping my bike right down. I've removed the swingarm pivot bolt flanged nut, but the bolt wont come out.
I think the answer is no, but is the frame threaded where the nut is?
I'm guessing it should come out with some heat and tapping...but it's very stubborn.
Cheers!
Swingarm pivot bolt.
Ewetea
- My Bike: ZXR400L5
Re: Swingarm pivot bolt.
viewtopic.php?f=124&t=8001
I had a similar problem and the above link might help you resolve the problem. I have a spare bolt should you need it.
- Dominik
- My Bike: Zxr 400 L3
The frame isn´t threaded there so you can apply as much force as you can to on the axle. If you can´t get it out with a hammer you could try a press somewhere for example with a big clamp...
Zxr 400 SL - 130kg
