Elictrical problem
asandilands69
My Bike: ZXR400 SP / R1
Elictrical problem
Post by asandilands69 »
ello people...hopefully somone out there can shed some light on this problem as its doin my head in tryin to sus it!
basically...my full beam doesnt work as it should, heres what happens.
switch the lights onto half beam and they work fine, flick to high beam and it switches down to parking light, flick back to low beam and it works fine...flashes do nothin altho the relay does click which to me shows power is going to it. When the bike was mot'd at a local garage the bloke got the full beam working by inside the fuse box bridging the low beam fuse to the high beam and told me i would need a new fuse box...which i have...well, a second hand one but i still have the original problem...
Dubstar
Re: Elictrical problem
Post by Dubstar »
sounds like the wire from relay to the head light is broken somewhere ?!
:smt012
asandilands69
but if that is the case...why does it work when the two fuses are bridged?
could be a corroded earth strap, i had these lighting problems cleaned the earth strap from the battery and all was fine.
Northern ANdy
My Bike: Unique ZXR400
Post by Northern ANdy »
does the relay click when you shift to high beam from dip? Or just when you use the flasher?
Get the mulitimeter out and have a poke about, seems very odd.
Andy
asandilands69
when you say the earth strap off the battery do you mean the neg' battery terminal or something else? had the multometer out and couldnt find anythin but im no expert...
asandilands69
errrm there is a click when i shift to high beam but doesnt seem as loud as when i use the flasher...
asandilands69 wrote:when you say the earth strap off the battery do you mean the neg' battery terminal or something else? had the multometer out and couldnt find anythin but im no expert...
yes mate the negative strap from the battery, could be any earth lead tbh so have a look around for any corroded connections.
asandilands69
ok cheers i'll have a look.
did you ever sort this mate? what was it??
MillaMeter
Post by MillaMeter »
Buy yaself some vasaline or WD40 and pack all the connection blocks behind the headlight with it. Give the wires a wiggle while you flick the main beam on and off to pin point the bad wire if there is 1. I had this problem once on 1 of my old bikes, the metal pin that crimps the wire that then clips into the connection block had worked it's way loose and fell out giving me no lights.
Failing that, take the tank off and you'll see an earth connected to the frame just above the fuel pump, make sure that's connected good and tight.
Or... put a bigger fuse in the main beam slot? It is 15amp right? Or is it 30? Maybe change ya bulbs?
Let us know how you got on :smt002
Regards
Rich
never put in a larger than required fuse, thats just asking for a fire! Fuses are there to protect the equipment it suplies, and if its too large any excessive current will either burn the wiring out, start a fire or if your lucky just bugger up whatever its supplying!
